tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
May 03, 2014Tutor
Looks like there are some old transmission files:
-rwxr-xr-x 1 root root 7593660 Oct 31 2011 /usr/local/bin/transmission-cli
-rwxr-xr-x 1 root root 7808113 Oct 31 2011 /usr/local/bin/transmission-create
Best way to start again is to install the same add-on and then uninstall it. It should remove all related add-on files.
The /root/.config/transmission-daemon is the default location of the config files if you do not specify the TRANSMISSION_HOME env variable. You can safely delete this directory.
