tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
eton
May 04, 2014Luminary
tarobun wrote: Looks like there are some old transmission files:
-rwxr-xr-x 1 root root 7593660 Oct 31 2011 /usr/local/bin/transmission-cli
-rwxr-xr-x 1 root root 7808113 Oct 31 2011 /usr/local/bin/transmission-create
Best way to start again is to install the same add-on and then uninstall it. It should remove all related add-on files.
The /root/.config/transmission-daemon is the default location of the config files if you do not specify the TRANSMISSION_HOME env variable. You can safely delete this directory.
I actually did install and uninstall super-poussin' and WhoCares' Transmission versions before installing your version. But now I went through that procedure again. Uninstalled yours, installed WhoCares' version and uninstalled it, installed super-poussin' and uninstalled. But these files remains:
# find / \( -path '/c' -o -path '/USB' \) -prune -or -iname '*transmission*' -exec ls -ld {} \;
drwxrwsr-x 2 root admin 16384 May 4 10:34 /etc/transmission-daemon
drwxr-xr-x 5 root root 16384 Apr 29 16:06 /root/.config/transmission-daemon
-rw-r--r-- 1 root root 6095 Jan 14 2009 /usr/local/man/man1/transmission-remote.1
-rw-r--r-- 1 root root 2964 Jan 14 2009 /usr/local/man/man1/transmission-daemon.1
-rw-r--r-- 1 root root 3838 Jan 14 2009 /usr/local/man/man1/transmissioncli.1
-rw-r--r-- 1 nobody nogroup 6 May 4 10:44 /var/run/transmission-daemon.pid
-rw-r--r-- 1 root root 8644 May 1 14:00 /var/tmp/transmission.logCan those files be safely deleted?
