tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
eton
May 05, 2014Luminary
Update. I deleted the files listed above (also /c/addons-config/Transmission) and after that the installation of tarobun's Transmission went just fine!
