tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
May 21, 2014Tutor
Updated to version 2.83
Changes:
All Platforms
Daemon
Web Client
Changes:
All Platforms
- Licensing change: the GNU GPLv2 code can now be used under GNU GPL v2 or v3
- Fix network hanging issues that could occur when both UTP and DHT were enabled
- Fix 2.82 file descriptor leak when importing a blocklist
- Disallow torrents that contain "/../" in the path
- Fix 2.82 bug that didn't retain peers between sessions
- Fix potential dangling memory error in UDP tracker DNS lookups
- Remember a torrent's "queued" state between Transmission sessions
- Updated third party libraries: DHT updated to v0.22; miniupnpc updated to v1.9
- Autoconf script fixes: better detection of ccache, minupnpc
- Fix the X-Transmission-Session-Id header to be valid with the SPDY protocol
- Fix thread safety bugs in the tr_list datatype
- When determining free disk space on NetBSD>=6, support its Quota feature
- Windows portability improvements
Daemon
- Use libevent's event loop
- Fix discrepancy in curl SSL setup between tr-daemon and tr-remote
Web Client
- Support file renaming in the web client
- Fix incorrect torrent state being displayed for magnet links
- Make URLs in the torrent's comment field clickable (and sanitize them to prevent cross-scripting)
