tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
smashman42
Oct 22, 2014Guide
Just had my settings.json file corrupt itself for no apparent reason. Couldn't get to the web interface, and in Frontview it said the service was started/running but the green light was greyed out.
Renamed the corrupt settings.json (couldn't even open the file to edit it), restarted the service so it would generate a new default , then stopped it again to tweak the settings to how I like them.
Everything had been working fine for the last month or two since I got rid of the old 2.42 by Super-Poussin(sp?) and updated to Tarobun's 2.84, so no idea how/why this happened. No power cuts, drive problems, or NAS locking up. Just thought I'd note it here just in case someone else runs into the problem.
Oh, seeing as I was messing around in Frontview anyway I updated to the latest RAIDiator 4.1.14 firmware after fixing Transmission, so far no dramas with the update as far as I can tell. I don't use the watch-dir so no idea about emk's problem, sorry.
