tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Mr_B
Nov 02, 2014Guide
Took me for ever to get around to this. Sorry. I just tested it on my system. Had to configure a watch dir, and such since i wasn't using one. But after that it was working as a charm. You might want to double check so you got:
emk wrote: Anyone else having watch-dir issues with 2.84? Seems any torrent files dropped in my watch-dir aren't being loaded. Was working on 2.83 and earlier.
"watch-dir": "where ever"
"watch-dir-enabled": true
in your settings.
B!
