tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
emk1
Nov 03, 2014Aspirant
Ii appears I got it working after testing a few things. Firstly, I tried changing "watch-dir-enabled": the value has always 1, not true. So I tried playing around with this, but the true/false value definitely doesn't work for me. Only binary 0 or 1 work.
Secondly it appeared to be a permission problem, depending on which machine I drop the file from or how I connect to the share (e.g.: sometimes I drop directly from either mac/PC at home, sometimes I drop it when I VPN in from remote location. Sometimes I even SCP the file over). I also restarted my box to flush any gremlins out, good old Windoze fix never hurt anyone right :D
