tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Mr_B
Nov 03, 2014Guide
I copied the variables from my settings.json after i set it up so it was working. If you got a different need in your settings.json, then your most likely not running the same addon. I'm running the one posted in this thread.
emk wrote: Ii appears I got it working after testing a few things. Firstly, I tried changing "watch-dir-enabled": the value has always 1, not true. So I tried playing around with this, but the true/false value definitely doesn't work for me. Only binary 0 or 1 work.
When i went to test it out, i didn't have the variable for enabling, or setting the path to where, so i went and got them from this list, according to which the supposed values are indeed true / false, not 1/0.
Anyway, what ever you had to do to get it working, gratz.
B!
