tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
emk1
Nov 03, 2014Aspirant
I think I had the least amount of success with SCP regarding the watch-dir. Maybe the file perms got screwed up because I'm copying over as root. Dropping the file into the dir with AFP/CIFS seems to retain the correct perms for it to work.
I definitely am using this version of Transmission (I have NV+ v1). Previously I was using Super Poussin's addon up to v 2.42 (where he stopped supporting it). Moved onto v2.8x when I found that it was available and continued to use Poussin's email script and settings.json file for config.
