tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
mememel
Feb 08, 2015Aspirant
Hi
I've problem with Transmission 2.84. I tried many search.
Any torrent would like start (private and public torrent), and i tried the SAME torrent file on a 2.84 transmission on my Laptop ubuntu and it works perfectly.
The configuration are same.
Transmission say :
Announce error: Could not connect to tracker - Today 06:23:20 PM
Next announce in 9 minutes
Scrape error: Could not connect to tracker - Today 06:25:05 PM
Config on Transmission 2.84 on ReadyNas Duo RAIDiator 4.1.14 :
And my 51413 port is open on my router, but transmission show "port is closed".
Upnp is turn on on the router.
And is the past, the add on works perfectly (10 days ago). I don't change any thing. I don't unterstand.
Is there a LOG file for Transmission 2.84 on the Nas Readynas Duo ? How and where I can find it ?
Transmission say :
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": false,
"blocklist-url": "http://www.example.com/blocklist",
"cache-size-mb": 2,
"dht-enabled": false,
"download-dir": "/c/media/BitTorrent",
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 0,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/c/media/BitTorrent/_incomplete",
"incomplete-dir-enabled": true,
"lpd-enabled": true,
"message-level": 2,
"peer-congestion-algorithm": "",
"peer-id-ttl-hours": 6,
"peer-limit-global": 200,
"peer-limit-per-torrent": 50,
"peer-port": 51413,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"port-forwarding-enabled": true,
"preallocation": 1,
"prefetch-enabled": 0,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": false,
"rename-partial-files": true,
"rpc-authentication-required": false,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{c16e9303ec8d8827bad4d9e94a864103a087edc5bLqTQnoT",
"rpc-port": 9091,
"rpc-url": "/transmission/",
"rpc-username": "",
"rpc-whitelist": "127.0.0.1,10.0.0.*,192.168.*.*",
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 100,
"speed-limit-up-enabled": false,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 18,
"upload-slots-per-torrent": 14,
"utp-enabled": false,
"watch-dir": "/c/media/BitTorrent/_watch",
"watch-dir-enabled": false
