tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Jun 03, 2015Guru - Experienced User
Same question for you - did you verify that the port is still forwarded to the current internal IP address of the NAS?
Also you can verify the port status with http://www.canyouseeme.org/ from a PC.
