tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
eton
Jun 06, 2015Luminary
addict wrote: still struggling with this ... all inbound connections seem to connect, I can ping Internet domains from the NAS (via ssh), and i can see in my router that there are inbound connections to my NAS IP and Transmission listen port that are in TIME_WAIT or UNREPLIED state. Further, if I look at outbound connections from my NAS I see outbound connection to 239.255.255.250 in UNREPLIED state. Internet search seems to indicate this is related to UPnP. I have to wonder if some UPnP "test' is failing, thus making Transmission think the port is closed, and it won't respond to inbound connections. There are several other connections in UNREPLIED state as well, so I feel like the connections are coming in, they're getting to the NAS, it's just not sending any data back. So perplexing. Any other ideas, anyone?
What bit-torrent ports are you forwarding from router to NAS? And I hope you have reserved an IP address to the NAS MAC address.
I have these ports forwarded to my NAS: 51413, 6881-6889
