tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
addict
Jun 06, 2015Aspirant
I'm currently using Upnp With no specific ports set up for forwarding (as per instructions on the Transmission wiki). I _had_ been forwarding just 1 port to the static IP of my NAS, not using UPnP, and disabling random port use (thus, not forwarding any defined range of ports)
