tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
addict
Jun 06, 2015Aspirant
oddly, there are no tracker errors, just Transmission showing Port Closed and no peers connected. I'll disable UPnP, go back to static routing, and try the same set of ports you used to see if it does anything. Thank You for replying!
