tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Mr_B
Jun 09, 2015Guide
I have to ask again, what, exactly, is used to test the port, and gets the answer that it's closed, to make you guys default to thinking that transmission is at fault?
At this point nobody can help you since they cant reproduce the error, and quite frankly, the error assumed, and the error messages supposedly being had according to the last few posts, doesn't add up.
The communication with the TRACKER has NOTHING to do with the forwarded (or not) port for Transmission. If you can't reach the tracker, the problem isn't the port being forwarded or not.
B!
B!
