tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
eton
Jun 10, 2015Luminary
Another idea.
You can't use blacklists with some trackers. Or put it this way, blocklists are getting too greedy.
