tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
mdgm-ntgr
Jun 18, 2015NETGEAR Employee Retired
Did you ever manually edit the config? If so, did you make sure to edit it using an appropriate text editor.
