tarobun
Nov 24, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091.
If it doesn't work after installation, try rebooting.
Not sure if it can be install over the top of super-poussin's version, but if you are planning on uninstalling super-poussin's version then remember to save the torrent files somewhere else first.
To quote myself:
Thanks to super-poussin for the original Transmission add-ons.
Enjoy!
Transmission_2.73.bin - http://www.mediafire.com/?ajpyyc7ujv54o37 no-utp
Transmission_2.75.bin - http://www.mediafire.com/?gbmbhu3hrabf9fe
Transmission_2.76.bin - http://www.mediafire.com/?389i53w9w9rtosm
Transmission_2.77.bin - http://www.mediafire.com/?pm420vuajaim9bz
Transmission_2.80.bin* - http://www.mediafire.com/?5s7dag8ko72doj1
Transmission_2.81.bin* - http://www.mediafire.com/?x4pvvidrgb36df2
Transmission_2.82.bin* - http://www.mediafire.com/?rbctsdae000zoav
Transmission_2.83.bin* - http://www.mediafire.com/?31iul25i0t12qda
Transmission_2.84.bin* - http://www.mediafire.com/?rh5fge4mc8ahzw4
*if the "Upload" button doesn't work or the "Destination folder" field is blank, reload the webpage.
To quote myself:
tarobun wrote: It looks like upgrading from Transmission 2.42 to this Transmission add-on is a no-no. Sounds like there are conflicting configuration that screws up both installs. :( (eg. /c/addons-config)
It seems the best approach is to fully uninstall the old, delete the config directory, and then install this add-on. Once you're on this add-on, updating is straightforward and can be done over the existing version.
Just a fyi - the default download dir is /var/local/Downloads and there is no username and password with this add-on. If you are prompted for them then the old version was not fully uninstalled.
Enjoy!
- etonLuminaryI've had no problems with watch-dir. And I am also using settings from old super-poussin's version, but I edited them and inspected each line carefully when switching to tarobun's version.
viewtopic.php?t=75559 - emk1AspirantI think I had the least amount of success with SCP regarding the watch-dir. Maybe the file perms got screwed up because I'm copying over as root. Dropping the file into the dir with AFP/CIFS seems to retain the correct perms for it to work.
I definitely am using this version of Transmission (I have NV+ v1). Previously I was using Super Poussin's addon up to v 2.42 (where he stopped supporting it). Moved onto v2.8x when I found that it was available and continued to use Poussin's email script and settings.json file for config. - Mr_BGuide
I copied the variables from my settings.json after i set it up so it was working. If you got a different need in your settings.json, then your most likely not running the same addon. I'm running the one posted in this thread.emk wrote: Ii appears I got it working after testing a few things. Firstly, I tried changing "watch-dir-enabled": the value has always 1, not true. So I tried playing around with this, but the true/false value definitely doesn't work for me. Only binary 0 or 1 work.
When i went to test it out, i didn't have the variable for enabling, or setting the path to where, so i went and got them from this list, according to which the supposed values are indeed true / false, not 1/0.
Anyway, what ever you had to do to get it working, gratz.
B! - emk1AspirantIi appears I got it working after testing a few things. Firstly, I tried changing "watch-dir-enabled": the value has always 1, not true. So I tried playing around with this, but the true/false value definitely doesn't work for me. Only binary 0 or 1 work.
Secondly it appeared to be a permission problem, depending on which machine I drop the file from or how I connect to the share (e.g.: sometimes I drop directly from either mac/PC at home, sometimes I drop it when I VPN in from remote location. Sometimes I even SCP the file over). I also restarted my box to flush any gremlins out, good old Windoze fix never hurt anyone right :D - Mr_BGuide
Took me for ever to get around to this. Sorry. I just tested it on my system. Had to configure a watch dir, and such since i wasn't using one. But after that it was working as a charm. You might want to double check so you got:emk wrote: Anyone else having watch-dir issues with 2.84? Seems any torrent files dropped in my watch-dir aren't being loaded. Was working on 2.83 and earlier.
"watch-dir": "where ever"
"watch-dir-enabled": true
in your settings.
B! - Just had my settings.json file corrupt itself for no apparent reason. Couldn't get to the web interface, and in Frontview it said the service was started/running but the green light was greyed out.
Renamed the corrupt settings.json (couldn't even open the file to edit it), restarted the service so it would generate a new default , then stopped it again to tweak the settings to how I like them.
Everything had been working fine for the last month or two since I got rid of the old 2.42 by Super-Poussin(sp?) and updated to Tarobun's 2.84, so no idea how/why this happened. No power cuts, drive problems, or NAS locking up. Just thought I'd note it here just in case someone else runs into the problem.
Oh, seeing as I was messing around in Frontview anyway I updated to the latest RAIDiator 4.1.14 firmware after fixing Transmission, so far no dramas with the update as far as I can tell. I don't use the watch-dir so no idea about emk's problem, sorry. - emk1AspirantAnyone else having watch-dir issues with 2.84? Seems any torrent files dropped in my watch-dir aren't being loaded. Was working on 2.83 and earlier.
- tarobunTutorThanks!...
Updated to version 2.84
Changes:
All Platforms- Fix peer communication vulnerability (no known exploits) reported by Ben Hawkes
- vatazhkaAspirantTransmission 2.83 is vulnerable to peer communication vulnerability. More details are available in Gentoo bug tracker at https://bugs.gentoo.org/show_bug.cgi?id=516822. Version 2.84 contains fix for this vulnerability.
- etonLuminaryThanks for the new version tarobun!
Just updated, wokring fine.
