super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- Ma2TAspirantThanks for your work super-poussin!
I decided to update from 1.72 Lite, to the new 2.02, but it never connected to the interface. Tried disabling and enabling it a few times, and a restart, but still no luck. The torrent creation page worked though. I also set the "umask" value.
Then I tried 2.03 for Sparc (Duo,NV+...) same problem.
BUT 2.01 seems to work without a problem :) - super_poussinVirtuoso
Ma2T wrote: Thanks for your work super-poussin!
Thanks
I will produce a debug version to better understand what's happen on sparc - super_poussinVirtuoso
can you download 2.02 official again from this site. it should produce a message in frontview log in case of error during install - super_poussinVirtuoso2.03 is out for x86 , Sparc version will follow
- cip74coolAspirantI have an issue with alt-speed scheduling in Transmission 2.01 on NV+ 4.1.7.
I've enabled alt-speed (see settings.json lines below), but instead of throttling down to Turtle Mode between 1080 (i.e. 18:00) and 1425 (i.e. 23:45), it actually throttles down outside of this time window (1425 to 1080), going max speed between 1080 and 1425.
Has this happened to anybody else? Is this a bug or am I doing something wrong? If it's a bug, is it solved in 2.02 or 2.03?
Thanks!
"alt-speed-down": 200,
"alt-speed-enabled": false,
"alt-speed-time-begin": 1080,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": true,
"alt-speed-time-end": 1425,
"alt-speed-up": 20, - DynasAspirantLoaded v2.03 x86 on a ProPioneer. Still not able to invoke the web UI interface. Yet, the "Create Torrent" interface works though.
Any ideas? - super_poussinVirtuosois it possible to have ssh access to diagnose I'm not able to reproduce the issue on my pro/NVX or Ultra
If yes PM me , I need clearly understand what's happen on some units - super_poussinVirtuosofor people whor are looking for the peer tab in web UI : This feature was removed from official version but is in beta version (past and upcoming)
- Blues11Luminarysuper-poussin, once again, thank you for your hard work. I have a question about 2.03.
I removed my older version and installed the latest. I don't want to get emails so I've renamed the file in /c/addons-config/Transmission to no_email-allowed, but I keep getting emails when a torrent completes.
I stopped and then restarted Transmission, but it's still sending emails. Is there an additional secret to turning email notification off?
Thank you,
Blues - DynasAspirant
Dynas wrote: Loaded v2.03 x86 on a ProPioneer. Still not able to invoke the web UI interface. Yet, the "Create Torrent" interface works though.
Any ideas?
Super-possin, thanks again for your effort and offer to help.
The problem seemed to be solved after I removed Transmission and cleaned up /c/webroot/transmission; then installed v2.03 again. Not sure if this is any help.
