super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- varsasAspirant
sdouek wrote: Download add-on from here http://readynas.com/forum/viewtopic.php?f=47&t=24271 then load add-on in frontview>update>local
Thanks but there's still a question regarding the removal of watchdog in 2.11? I'll have to manually add torrent to Transmission rather then just copy them to a directory? - sdouekGuidetry using "transmission remote"
- varsasAspirant
sdouek wrote: try using "transmission remote"
The note regarding watchdog removal refers to root being filled, isn't it possible to get watchdog to use another location like Flexget as noted under configuration: http://flexget.com/wiki/InstallWizard/ReadyNAS ? - super_poussinVirtuoso
varsas wrote: sdouek wrote: try using "transmission remote"
Watchdog is now include in transmission
Super-Poussin
If you like my add-ons please donate :) - sdouekGuidePoussin you are truly Super :)
- HELP!
I have a couple of issues.
I recently updated my Duo firmware to 4.17, and took the opportunity to clean up my NAS at the same time, so I also formatted the disks so that everything was as new again and all my old junk was gone forever. I backed up my old "addon-config" and "webroot" folders and files prior to formatting so I could just put them back afterwards. (And edit if necessary)
OK, that's the background info out the way.
I've installed the latest Transmission. (2.11) and instead of using the default directory, I decided to create my own and then edited my backed up versions of the Transmission files in "Addons-Config" and "Webroot" with my new download location, while keeping all my other previous torrent settings the same. (Port, username, pass, etc)
However now Trans' won't open via the browser. (Either via Frontview or my previous bookmarked page) My router is still configured the same as when it was working.
The message Firefox gives me is: Firefox can't establish a connection to the server at 1XX.XXX.X.XXX:8181
Suggestions welcome please!
PS. PHP 1.3 is installed, and was installed first. Everything was running fine prior to 4.17 update. - super_poussinVirtuoso
InTheShires wrote: HELP!
install transmission again - varsasAspirantI just tried to install Automatic from here: http://www.readynas.com/forum/viewtopic.php?f=48&t=41667 but there was a checksum problem and clearly it's actually for the Pro NAS; is a Duo NAS version? Or should I go for Flexget?
- sdouekGuide
varsas wrote: I just tried to install Automatic from here: viewtopic.php?f=48&t=41667 but there was a checksum problem and clearly it's actually for the Pro NAS; is a Duo NAS version? Or should I go for Flexget?
try viewtopic.php?f=47&t=41666&start=0 for the duo and you posted in the wrong thread this question does not belong here. Mod can you move the question and answer to proper location. - user1011AspirantHello,
I'm trying to install transmission 2.12 on my readynas nv+ and got invalid checksum.
Firmware: RAIDiator 4.1.7 [1.00a043]
