super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- Deaf_Raiders1Aspirant
Mr_B wrote: Deaf, not behaving like that here. Does it behave the same way regardless of how many torrents you got active? (how many do you have in transmission?)
B!
I only have one active torrent. - Mr_BGuideI was thinking along the lines of it running out of memory due to to many active torrents, or something, but thats hardly the case then. Sorry, no idea.
B! - CrommAspirantThere's another thread on that topic and the recommendation is to change the default-cache size from 200 down to 8 or less.
Cromm wrote: There's another thread on that topic and the recommendation is to change the default-cache size from 200 down to 8 or less.
Is that aim at me? - Deaf_Raiders1Aspirant
Deaf_Raiders wrote: Cromm wrote: There's another thread on that topic and the recommendation is to change the default-cache size from 200 down to 8 or less.
Is that aim at me?
I suppose that post was aimed at me and i changed the config file and it worked :) Cheers all good now :D - CrommAspirant
Deaf_Raiders wrote: Deaf_Raiders wrote: Cromm wrote: There's another thread on that topic and the recommendation is to change the default-cache size from 200 down to 8 or less.
Is that aim at me?
Yep sorry should have quoted on the previous reply. Fixed mine issue with it too, so I figured I'd spread the info around.....now if only I could
get iTunes 10.5 to see the iTunes server (1.0.3) for more then 5sec and I'd be good. - Deaf_Raiders1AspirantI had that issue too I changed my NAS IP address and then updated my iTunes to see it.
- ngalarneauAspirantI'm getting an error on the Arm version of Transmission:
403: Forbidden
Unauthorized IP Address.
Either disable the IP address whitelist or add your address to it.
If you're editing settings.json, see the 'rpc-whitelist' and 'rpc-whitelist-enabled' entries.
If you're still using ACLs, use a whitelist instead. See the transmission-daemon manpage for details.
Any have any idea how to add my IP to the whitelist or disable it? - WhoCares_MentorWhat is your IP address, are you trying to access Transmission web interface from outside your LAN?
-Stefan - Mr_BGuide
Mine just went inactive. Not after a few minutes but a couple of weeks of uptime. Tried restarting the NAS to get it resolved and it seams to have done it for now.Deaf_Raiders wrote: Is anyone having problems with it going inactive after a few mins after booting it on?
What thread would that be? I might need it soon.Cromm wrote: There's another thread on that topic and the recommendation is to change the default-cache size from 200 down to 8 or less.
B!
