super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- ludovit8Aspirantnot, login for that addon, but I find it now... admin and password1 :-)
- LitozAspirant
kugar wrote: I have exactly the same problem, when I start Transmission manually, I have a message : Transmission starts with errors. And it doesn't starts automatically when I reboot the nas.
I have a readynas Ultra 4.
Have you find any workarround for this? I'm getting the same problem with my ultra 2. - onezeroAspirantHi, have any of you guys been able to enable either a proxy
or vpn on your readyNAS device to hide torrent traffic?
I know that there were proxy options in an earlier version of
transmission, and that they have taken that out now..
But perhaps somebody has built something that can fix it somehow?
Hoping for some positive answers! :)
BR, K - AMRivlinApprenticewhen did torrent traffic become illegal? BitTorrent is a legitimate program for exchanging data.
I know that isn't the answer you were looking for, but Im curious why a proxy is needed?
You could "hidemyass" at the router level. - LitozAspirant
onezero wrote: Hi, have any of you guys been able to enable either a proxy
BR, K
You can fin the proxy parameters here:
http://www.readynas.com/contributed/super-poussin/Transmission-Parameters.htm
Remember to stop the add on before change the config file and to back it up just in case.
Good luck - c014AspirantI can not get this thing to stop sending me mails everytime it's finished a download, how can I turn off mail notifications?
- JarnoGGuideThere's a setting in your settings.json file called "script-torrent-done-filename", replace whatever is after it by "" and save the file.
Before you edit the file, you should stop Transmission. - paalfeGuideDoes watch-dir work? What am I doing wrong!?
I have a ReadyNAS Ultra 6 with RAIDiator 4.2.22.
I have installed Transmission_2.77.01.bin
I have customized /addons-config/Transmission/transmission-daemon/settings.json (Stopped Transmission before editing)
"trash-original-torrent-files": true,
"watch-dir": "/c/storage/downloads/torrent/torrent_autostart/",
"watch-dir-enabled": 1
I have tried setting "watch-dir-enabled" to true instead on 1, did not help.
I have set chmod 777 on "/c/storage/downloads/torrent/torrent_autostart/", admin is the owner and users is the group.
Transmission will not autoload torrent files I put in "/c/storage/downloads/torrent/torrent_autostart/".
If I load the torrent file manually with the web interface or a transmission remote gui the torrent works fine. - chrizAspirantI'm using Transmission 2.77 on my Ultra 2 (Radiator 4.2.22) and I am downloading directly to a usb drive. My NAS powers off at night and turns on again in the morning, and I'm having a strange issue every morning that all my torrents gives the same message:
Error: No data found! Ensure your drives are connected or use "Set Location". To re-download, remove the torrent and re-add it
Resuming the torrents works just fine, but it's a bit of pain in the ar#$ to do every day :) I'm assuming this has something to do with the Transmission service starts before my drives are mounted, but I'm not 100% certain..
Anyone with the same issue - and/or even better - a solution?? :)
/ChriZ - hooperAspirantAnyone else seeing a could not connect to tracker error? If I start and stop the Transmission service, it will connect to the tracker just fine. It just seems to stop connecting after a while. Suggestions for troubleshooting this? The tracker is torrentleech.org
