super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- adeptusAspirantI had to do a hard power down as I couldn't access the transmission web interface and even the frontview was extremely slow (cuz 'blocklist' process was sucking up 99% of CPU). After the hard powerdown, there's a volume resynch going on for many hours, so after that I will just upgrade to the latest beta. I could just leave 2.0 and see what happens again tomorrow morning, but let's face it, it's a cronjob that would just get initiated again at x time (5:30AM?). I only had 5 or 6 torrents downloading each with 2 to 10 files each and all the torrents added up to 4GB or less, so no recheck should suck-up 99% CPU for 2-3 hours. utorrent doesn't behave like that on a single CPU system even with 20 re-checks going on, so I attribute that to bad coding somewhere in Transmission. Sorry guys, I need this thing working, don't have a lot of time for being a beta tester, but I do appreciate your support. If I do catch it doing that again, I'll do the ps -ef somebody else requested and post it here.
Thanks,
Adeptus - super_poussinVirtuosocurl should stop if file not accessible .
can you chheck if you can download : http://update.transmissionbt.com/level1.gz ?
a 404 or bad dns resolut stop the script quickly
a download and update of the blocklist take less than one minute on my units - veehexxAspirant2.01b7 sparc feedback...
- long delay when disabling the transmission addon (felt like ~90seconds). starting the addon is fine.
- torrents not resuming when transmission starts (torrent ID's are being written to applicable .txt files on disable though). i've left it over 2minutes since transmission was started.
- i like the torrent create area you've done at http://[nasip]/transmission. good work! :) not tested it yet but looks very simple!
- if the start/stoptrans.sh already exist, it should not over-write (unless theres been an update to the scripts :)). saves re-entering your passwords on every update. - super_poussinVirtuosostart.sh and stop.sh are saved I think , let me check if I forget to replicate the change from x86 build to Sparc
- super_poussinVirtuosowill publish in a few minutes a b08 let me know if it's better
thanks - super_poussinVirtuosoYou can download it :)
veehexx wrote: 2.01b7 sparc feedback...
if b08 is always slow for you could it be possible to have ssh access to diagnose ? - veehexxAspiranti found the cause of slowness with b08...
it appears the transtop.sh script pauses each torrent after writing the torrent ID to the appropriate .txt; correct operation.
however, it appears to pause 1 torrent per 5 seconds (linked to default 5sec RDC refresh of webgui?), so 20 torrents take 5x20.. 100seconds.
i've not timed it exactly, but it seems about right!
i've tried with 5 active torrents. 5x5 = 25seconds, so my theory seems true.
transmission service is still running, so webgui is still alive; you can see each torrent changing to the pause status as the transmission service closes down.
no change with the transtart.sh either; torrents are not in their last state when starting the addon.
im shooting offline now, but i'll have SSH setup for you tomorrow morning if you still require it! - super_poussinVirtuosoAgree with yes
Yes please, I need to diagnose - veehexxAspirantygpm S-P!
