super_poussin
May 17, 2010Virtuoso
New Transmission add-on thread
The previous thread was very long
time to open a new one and prepare the 2.0 :)
- vspbAspirant2.02b03 working, thanks ...
- Putte1AspirantHi all!
Are there any knows issues with transmission? as this is really buggy for me, are there any other addons that it don't work with etc?
I have installed Radiator 4.16
did install 2.01 did not get it to work, see posts I have made earlier in this thread, it di crash when trying to access it with https, could not remove it as I get a error.
I did a factory default, installed ToggleSSH & EnableRootSSH, apt-get, dyndns addon, Transmission.
I did try it, suddenly the seeding did stop and I could not get it to work again, downloading worked without any problems, now it started to act like before again, crashing when trying to access it via https, not runing when booting the nas, can't remove the addon as I get a error when trying to remove it.
I installed the new one 2.03 still same problems. The worst art is I need to do a factory default o t remove the addon, aka i'll lose everything again.
/regards
Patrik - super_poussinVirtuosogive me ssh access to diagnose ?
you can also upgrade raidiator to 4.1.7 - Putte1Aspirant
super-poussin wrote: give me ssh access to diagnose ?
I did do a factory default again.
Now i'm trying rtorrent, so far it works without any hickups, did do the full installation.
/Patrik - DynasAspirantTrying to debug why Transmission 2.01 UI not working, with 4.2.12 and found the following in syslog
transmission-daemon[13684]: Unable to save pidfile "/var/run/transmission-daemon.pid": Permission denied (daemon.c:457)
Is this harmful or related to web UI issue? How does one get rid of this.
Thanks. - super_poussinVirtuoso
Dynas wrote: Trying to debug why Transmission 2.01 UI not working, with 4.2.12 and found the following in syslog
Thanks.
That's not a problem only a warning - super_poussinVirtuoso
Putte wrote: super-poussin wrote: give me ssh access to diagnose ?
/Patrik
It should work now - rjgouldAspirant
Ditto, have gone back to 2.01.vspb wrote: I installed 2.02 and was unable to connect to the web interface. Restarting NAS not helped. It seems that the 2.02 I have does not work - no network activity when you look at a router. Returned to 2.01 b10 (10809) - works again without problems. - super_poussinVirtuoso2.02 final should solve 2.02b02 issues
Did you test 2.02b02 , 2.02b03 or 2.02 official ?
