jerry_va1
Oct 31, 2014Aspirant
No torrent list, no daemon in Transmission Remote GUI
I have two ReadyNAS NV+ sparc. And two separate routers/LANs/static IPs to put them on.
My problem is Yury Sidorov's Remote GUI (5.0; there's an upgrade) for Transmission 2.42 (latest for my old ReadyNAS).
Admin of Transmission w/Remote GUI works fine in one NASbox on either LAN.
In the 2nd NASbox the Remote GUI gets past password access to the NASbox, but the daemon never runs, the "busy wheel" in the Remote GUI's upper right corner never turns, the file list of all torrents is never populated, the Remote GUI page remains empty. Behavioral failure is the same on both LANs.
The working NASbox is running NAS firmware 4.12. The NASbox with the not-working remote GUI has run both 4.14 and 4.12.
I have checked the json config file in use to be sure we all agree on the port.
I don't think this county has put much money into mental health facilities, so I would be grateful if someone could save me, I am going down fast.
Permissions in Frontview? Bad port forwarding in router? Some bug/corruption and I need to issue a manual command to start the daemon? (I have SSH to NASbox installed, brave but not good at Linux . . .)
With thanks in advance, so near yet so far,
--jerry-va
--jerry-va
1 Reply
- jerry_va1AspirantHow2 Clone Transmission Torrent Library to another ReadyNAS?
Hi. Me again. I copied a torrent library to a second ReadyNAS and can't administer it. Above I complain that the daemon won't start and the torrent list remains blank when I log onto the second ReadyNAS with the popular Yury Sidorov Remote GUI.
But this is bassackwards.
Shouldn't I be asking, How do you clone a Transmission torrent library onto another ReadyNAS?
I copied the data delivered by the torrents (the music library), but I forgot to copy the database of short files that the daemon itself uses to keep track of the library. For us, those files are here (my non-working clone is in my 2nd ReadyNAS, "NASbox2"): NASbox2/addons-config/Transmission/transmission-daemon which contains folders- /blocklist
- /resume
- /torrents
Eureka! If there is nothing in those /torrents and /resume folders, then you get a blank admin screen -- nothing for daemon to do. Here's how someone described their content (a short 5 or 7kb file, one for each torrent) in https://trac.transmissionbt.com/wiki/ConfigFilestorrents/
This subfolder holds the .torrent files that have been added to Transmission. The files in this folder are named with a combination of the torrent's name (to make it human-readable) and a portion of the torrent's SHA1 hash (to avoid filename collisions from similarly-named torrents).
resume/
This subfolder holds .resume files that hold information about a particular torrent, such as which parts have been downloaded, the folder the downloaded data was stored in, and so on. These follow an identical naming scheme to the files in the torrents subfolder.
So let's not just copy the torrent data (music library), let's also copy the files into the daemon's /torrents and /resume folders. Done! No difference. Blank admin page.
So maybe the real question is, if all the received torrents plus all the daemon's /torrents and /resume data for those torrents are copied into a cloned ReadyNAS box, how do you re-initialize the Transmission app (service) in that box to incorporate that data? In a very different box mentioned here http://www.dd-wrt.com/wiki/index.php/Transmission_daemon the restart/reinitialize command we might need looks like this (after SSH'ing into the ReadyNAS):/opt/bin/transmission-daemon -g /mnt/data/torrents/.config/transmission-daemon
That may be the same for us as FrontView/Services/Installed Add-ons/Transmission/uncheck&"Save", a command that has been buggy for years. You get the message, "Service failed to start" but the light turns green and it has started. Or it really has not and you try again (firmware 4.1.12 and 4.1.13; 4.1.14 might be better).
Reinstalling the entire Transmission add-on clears/reinitializes the whole daemon folder area, so I'll try restarting. What's my next level of non-comprehension? Happy to hear from you while I tidy up around here for an approaching cold front and storm. Aren't we close to a solution here? Amazing how utterly stupid and obvious a mistake looks in hindsight.
