shaifulbusari's avatar
Sep 19, 2013
Object reference not set to an instance of an object
Greetings,
When I first installed the ReadyNas Remote, everything is working fine.
After restarting computer, keep getting the Object reference not set to an instance of an object which I googled and was unable to find any solutions.
Tried reinstalling but same error occurred.
Someone mentioned reinstall .net framework 2.0, tried that too but didn't work either.
Running Windows 8 64bit and installed the ReadyNASRemoteSetup_w8_v1.6.5.22
Any help or guidance is appreciated.
Cheers
1 Reply
  • Greetings,
    Managed to solved my issue.
    For those who is experiencing the same issue as me, it seems that the problem occur when I install ReadyNAS Remote without the ReadyDrop.
    Reinstalled ReadyNAS Remote with ReadyDrop and I'm able to run the ReadyNAS Remote.
    But now I'm facing another issue which I am unable to access my files remotely with ReadyNAS Remote.
    Cheers
