saudade
Aug 29, 2025Apprentice
Odd Firefox Behavior on Duo V1
Apologies in advance for the length of this post and numerous screenshots. My Ready Nas is a Duo V1. See pics below. I'm using FF 142.0.1 (but this issue has been going on for a while now. My D...
- Aug 30, 2025
saudade wrote:
If you've run into this before or have other suggestions, let me know.
I hadn't noticed it before, but I am seeing the same behavior with my own Duo. I am guessing this is a bug in FF, since other browsers work.
Also, I wasn't able to get to the shutdown screen in FF, I had to switch to Chrome to navigate there successfully.
saudade
<sigh> Looks like I attached the wrong image. I see nowhere to edit, so here's the rest.
Home screen with Backup menu.
After Selecting Backup Jobs. Menu closes and have double Duo.
Can get to Time machine (note I tried a few more times so you can see many Duos)
Then use the Tab to get to Backup Listings. (note jobs are running). Once here, I can access the logs, job properties, cancel, etc,
I'll skip the pics, but same thing happen under other main sections, For example, Under Network, select Interfaces and I get the collapse and extra Duo. If I pick Global Settings, I get in and then use the "Ethernet" tab
to move over (why NG names these tabs differently makes no sense but not the issue here).
