saudade
Aug 29, 2025Apprentice
Odd Firefox Behavior on Duo V1
Apologies in advance for the length of this post and numerous screenshots. My Ready Nas is a Duo V1. See pics below. I'm using FF 142.0.1 (but this issue has been going on for a while now. My D...
- Aug 30, 2025
saudade wrote:
If you've run into this before or have other suggestions, let me know.
I hadn't noticed it before, but I am seeing the same behavior with my own Duo. I am guessing this is a bug in FF, since other browsers work.
Also, I wasn't able to get to the shutdown screen in FF, I had to switch to Chrome to navigate there successfully.
Aug 30, 2025Guru - Experienced User
saudade wrote:If you've run into this before or have other suggestions, let me know.
- saudadeAug 30, 2025Apprentice
What's odd is I've used FF almost exclusively to access all of my "web enabled" devices (NAS, printer, router, etc.) since I brought my Duo back online and it's always worked fine. I don't think I'm that curios to roll back FF until it works.
Thanks for looking at it.
