saudade
Aug 29, 2025Apprentice
Odd Firefox Behavior on Duo V1
Apologies in advance for the length of this post and numerous screenshots. My Ready Nas is a Duo V1. See pics below. I'm using FF 142.0.1 (but this issue has been going on for a while now. My D...
- Aug 30, 2025
saudade wrote:
If you've run into this before or have other suggestions, let me know.
I hadn't noticed it before, but I am seeing the same behavior with my own Duo. I am guessing this is a bug in FF, since other browsers work.
Also, I wasn't able to get to the shutdown screen in FF, I had to switch to Chrome to navigate there successfully.
Aug 30, 2025Guru - Experienced User
saudade wrote:If you've run into this before or have other suggestions, let me know.
saudade
Aug 30, 2025Apprentice
What's odd is I've used FF almost exclusively to access all of my "web enabled" devices (NAS, printer, router, etc.) since I brought my Duo back online and it's always worked fine. I don't think I'm that curios to roll back FF until it works.
Thanks for looking at it.
