GJSchaller
Nov 11, 2014Guide
ownCloud 7.0.2 / Transmission 2.84 / SSL Error
I'm running a ReadyNAS Pro 4 on RAIDiator 4.2.27. Up until recently, I've been running Transmission 2.82 without issue.
Last night, I installed ownCloud 7.0.2. In the process of doing so, I needed to uninstall an old version of PHP that had been on my system, before reinstalling WhoCares? version of PHP and ownCloud. ownCloud is now up and running without issue.
However, now that ownCloud is running, I can no longer access Transmission via the web interface. When I try to browse to it, I get the following message in Firefox, and a similar one in Chrome:
I've reinstalled and repaired Transmission, but am hesitant to uninstall it unless there is no choice.
Any way to fix Transmission, without disturbing ownCloud?
Secure Connection Failed
An error occurred during a connection to gjschaller.homeftp.net:8181. SSL received a record that exceeded the maximum permissible length. (Error code: ssl_error_rx_record_too_long)
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
- super_poussinVirtuoso8181 is http not https I think
Envoyé de mon iPhone en utilisant Tapatalk - That may be the issue - it looks like when I go to http://(servername):8181, it redirects me to https automatically.
I'm rebooting the NAS now - when it comes back up, I will see if I have it set somewhere to force https in Owncloud, which might cause the issue. - That was the issue! Thank you for the assist!
I take it there's no SSL port for Transmission? (Just in case I wanted to enforce SSL across everything, to be more secure.)
