mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762 Owncloud for ARM (Duo/NV+ v2): http://www...
slobberbone
Feb 13, 2013Aspirant
So If I understand all, you connect to your ReadyNAs Duo with Putty (ssh) and you pull all lines before one by on.
In bash all line with # is a comment.
I explain the first 10 lines :
After that, when all it's ok, continue my instructions, if necessary I explain you the rest of the script later !
#!/bin/bash-> it's to specify in a script the shell used, in our case bash, the one you have probably when you connect with you putty
cd /tmp-> go in the /tmp directory
rm -Rf owncloud*.*-> remove old download packet of ownCloud
#wget http://mirrors.owncloud.org/releases/owncloud-latest.tar.bz2-> comment
wget http://mirrors.owncloud.org/releases/owncloud-4.5.5.tar.bz2-> wget is a tool that download the owncloud packet at this url (to adapt at the version you wish (you have to do that with all patches from the original provide by the ReadyXtra add-on)
#rm -Rf /usr/share/owncloud_*-> comment, before I removed the old backup instance of owncloud, but by security, : comment ;)
mv /usr/share/owncloud/ /usr/share/owncloud_save-> we make a backup of our owncloud instance
#tar -xjf owncloud-latest.tar.bz2-> comment
tar -xjf owncloud*.bz2-> wu untar the download packet of owncloud
