mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762 Owncloud for ARM (Duo/NV+ v2): http://www...
beniroquai
Jul 04, 2013Aspirant
If anybody is interested: It's possible to install owncloud on the new OS6 version. Just install the wordpress, PHP and MySQL package. Finally you can use the script provided in the earlier posts here. I did it as the following:
Create a MySQL-Database for Example:
Then install owncloud:
Then go to you browser and finish the installation routine. It's working perfectly! Htaccess might be tricky. Any suggestion how to handle it?
Type 'help;' or '\h' for help. Type '\c' to clear the buffer.
mysql> CREATE DATABASE owncloud;
Query OK, 1 row affected (0.00 sec)
mysql> GRANT ALL PRIVILEGES ON owncloud.* TO "owncloud"@"localhost"
-> IDENTIFIED BY "password";
Query OK, 0 rows affected (0.00 sec)
mysql> FLUSH PRIVILEGES;
Query OK, 0 rows affected (0.01 sec)
mysql> EXIT
Bye
cd /tmp
wget http://download.owncloud.org/community/owncloud-5.0.6.tar.bz2
tar -xjf owncloud-5.0.6.tar.bz2
mv owncloud /apps/wordpress/web
chown -R admin:admin /apps/wordpressweb
