mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on
Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762
Owncloud for ARM (Duo/NV+ v2): http://www.readynas.com/forum/viewtopic.php?f=147&t=64597
Owncloud for x86 (NVX/Ultra/Ultra Plus/Pro): http://www.readynas.com/forum/viewtopic.php?f=48&t=64596
Continues from http://www.readynas.com/forum/viewtopic.php?f=61&t=62063
- super_poussinVirtuosodid you try : http://rnxtras.com/
- DasQballAspirantLike a noob I went rogue on this owncloud updating and tried it (before I found the site with the instructions). I was actually getting somewhere, and luckily I didn't have anything set up to be worried about. Somehow during the process I messed up, and now I can access the owncloud from HTTP rather than HTTPS. I removed what I did, and removed the add-on through the Genie Apps, but after re-installing it the HTTP access is still allowed. Is it possible someone might know where I could change that back so that it only is allowed over HTTPS?
Also, is there any headway with Owncloud 5.0.11?
Thanks in advance, and I apologize for making the rookie mistake of thinking I could re-invent the wheel. - Duov2AspirantDoes anyone have the own cloud add-on 4.0.4 that you could send to me? readynasxtras does not host it anymore.
- karlblomquistAspirantI am also in need of the owncloud add-on for x86 on OS 4.x.x. If anyone can point me to it, thanks!
- chirpaLuminaryMaybe try posting on those forums; http://rnxtras.com/topic/owncloud
- ScouserAspirantWhere can I get this owncloud x86 on OS 4.x.x addo? Readynasxtras has stopped hosting it as already mentioned above.
Is there a reason why it is no longer available?
Anyone willing to PM me the .bin?
TIA - MastoulAspirantI have a readynas 104. I want to install the owncloud app but when all is finished and I am asked to create an admin account a message pops up that I have a corrupted webdav and I should check again the installation. What should I do?
- Retired_Memberwebdav on the NAS may be broken, check other means (https/network WebDAV drive mount, etc)
- beniroquaiAspirantI succesfully upgraded to OC7 with this: (on OS6)
wget
tar
rsync --inplace -rtv /data/home/Bene/owncloud-7.0.0.tar/owncloud-7.0.0/owncloud/ /apps/owncloud/web/
chown -R admin:admin /apps/owncloud/web/*
reboot - TobaxtAspirantDear all,
I am trying to get Owncloud running on my server, but I get the WebDav Error message, I also reinstalled PHP and Owncloud again. Also I can not access it via the Win8 client from Owncloud.
Has anybody a good idea what is wrong?
Thank you very much.
Kind regards,
Tobias
