toddel68
Apr 07, 2013Aspirant
Owncloud sqlite error
I just bought and installed the two addons necessary for owncloud on my ReadyNAS Duo . First php 5.3.20 and then Owncloud 4.07. After install, when I try to call up ownclouds setup page I get an error saying: "can not connect to database, using sqlite3. (could not find driver)".
Any ideas? I'm not into command line stuff, so if you can, please keep it simple. I would just give up on it but since I paid I (although only around 5$) I'm eager to make it work.
Thorsten
Thorsten
1 Reply
- toddel68AspirantUninstalled both since it was useless and it that completely f*** up my frontview. Theoretically I could have fixed the broken frontview via ssh (which I had installed) but since there was no howto I could find on that I decided to use my old 500Gb Disks which had just exchanged a few days ago. This sucks. Not sure if I want to give it another try and install php and owncloud again since it takes roughly 36 hours to swap HDDs as a restore method...
