Etz
Aug 16, 2011Aspirant
PHP5 5.3.6
If I want to upgrade from Super-poussins PHP addon, how do I do it? 1. Remove Super-poussin PHP 1.3 2. Install PHP5 5.3.6 from Who-Cares Am I correct? :roll:
Etz
Aug 28, 2011Aspirant
I remember taht after removing WhoCares addon, frontview failed to start, because apache had references to nox existing php libraries, which had to be removed manually... :roll:
Maybe If I dig around a bit I'll find my old post about that issue...
Yes... here it is:
viewtopic.php?f=36&t=48065
Should work also, if you delete php5.conf and edit httpd.conf accordingly...
Yes... here it is:
Etz wrote:
Only thing what I had to do is edit /etc/frontview/apache/addons/php5.conf
and remove first line from it which says:
LoadModule php5_module /usr/lib/apache2/modules/libphp5.so
Issue is that uninstalling this addon leaves that line there, preventing apache from starting.
If you try to start apache-ssl manually from shell:apache-ssl -f /etc/frontview/apache/httpd.conf
It already says whats wrong.
apache-ssl: Syntax error on line 261 of /etc/frontview/apache/httpd.conf: Syntax error on line 1 of /etc/frontview/apache/addons/php5.conf: Cannot load /usr/lib/apache2/modules/libphp5.so into server: /usr/lib/apache2/modules/libphp5.so: cannot open shared object file: No such file or directory
