Etz
Aug 16, 2011Aspirant
PHP5 5.3.6
If I want to upgrade from Super-poussins PHP addon, how do I do it? 1. Remove Super-poussin PHP 1.3 2. Install PHP5 5.3.6 from Who-Cares Am I correct? :roll:
WhoCares_
Sep 16, 2011Mentor
I'd say the instructions in the post from quickly_now quite nails it. To be extra sure you can look for leftovers from the old PHP add-on by doing this:
Also, to make sure that apache will start up correctly after removing an add-on, you can do
and check the output for any error messages.
And if you run into trouble, just ask for remote assistance using Teamviewer ;)
-Stefan
cd /etc/frontview
find . -name "*PHP*"
apache-ssl -f /etc/frontview/apache/httpd.conf -t
-Stefan
