willy134uk
May 07, 2012Aspirant
Plex Media Server for duo v2?
as the title says really is there a Plex Media Server for the duo v2? thanks :D
OzAy
Mar 26, 2013Aspirant
Hi,
I have a ReadyNAS Duo v.2 (arm chipset). I want to use PMS on NAS device. When I load PMS, it works fine but it couldn't find any metadata for my files.
I created a file (folders) for the movies, music's and pictures. I pressed the refresh button periodically but noting change. I found a file on the correct section and correct name but without info and cover.
When I load PMS on my w7 pc, everything works fine. I found a file on the correct section and correct name with info and cover. I like it.
My ReadyNAS works on my network which with 1Gbit ports. I use unlimited internet. When I check firmware for the NAS, it is update. It means internet is ok but is it possible, PMS couldn't find internet port on ReadyNAS?
How can I check it? How can I set it?
or anybody knows that problem?
Sorry my language,
Thanks,
Sorry my language,
Thanks,
