mathewbeall
Aug 14, 2012Aspirant
Plex on ReadyNAS Pro
Hi Folks, I have a ReadyNAS Pro (Business Edition) and just fired up the plex media server on it. Everything worked fine, but anytime I try to view a 1080p file (.m2ts or h.264 mkv) it can't keep ...
btaroli
May 30, 2013Prodigy
Jjnsgy wrote: Question for btaroli: clarification for you. "Further, I'd strongly recommend using native PLEX clients to DLNA." Do you set PLEX on your Samsung Smart TV to stream from DLNA or from PLEX?
There is no such thing. The PLEX app on Samsung is a native client. You *can* use the Samsung Internet TV app to attach to PLEX via DLNA, but that's a distinctly different experience. I've found the latter to be a bit of a disappointment, mostly because of the codecs it doesn't support. I've had better luck with DLNA on our PS3. :) In general, I do most of my @home PLEX viewing in the PLEX app on Samsung (second is PLEX on iPhone, when TV is busy).
