roggy1234
May 25, 2019Aspirant
Readynas 6 Pro - Stuck on "Readynas"
Hi guys, Hope you can help - Firstly a bit of history - I wanted to install the latest version of Plex on my Nas only to realise that I needed OS 6 (I had resisted OS 6 but now I needed to upgra...
Sandshark
May 25, 2019Sensei
Since testing the power supply unloaded is not a very good test, and you may not have an easy way to test it under load, you may want to go a different route. The power supply connections are identical to a standard PC ATX supply, You can temporarily connect an ATX supply (from an old PC) or even the one from the Ultra6.
roggy1234
May 26, 2019Aspirant
Thanks for replying guys -
USB os 6 recovery failed
Wasn't aware the pro 6 was an atx power supply - I'll give it a go
Weird as it was working up until the reboot
But I guess that's my only option unless there are any other suggestions?
- SandsharkMay 26, 2019Sensei
It's not an ATX supply, it's an SFX supply. But the connectors are the same, so you can use an ATX externally just for test or data recovery so you don't buy an SFX replacement and find out that's not the problem.
