kyle14786
Jun 20, 2012Aspirant
ReadyNAS DUO Bit Torrent Poor download with new connection
Hi All, Please help me before my NAS goes out the window! I have the Readynas DUO v2 which was plugged into the router from my previous service provider (SKY Broadband) and my internet connection ...
HERBIEO
It should not matter if you have manually done it look in the router logs under administration to see if there are incoming connection for the port you are using.
Edit: but you could try disabling upnp in the torrent client and forward it manually see if that makes any differance
don't turn off upnp in the router though.
