cam1700's avatar
cam1700
Follower
Feb 12, 2013
ReadyNAS Duo v1 apt-get cmd not found (After installing bin)
I have a ReadyNAS Duo V1, so apt-get doesn't come preinstalled.
Trying to install it has been a problem though, I have gotten the binary file from here: http://www.readynas.com/?page_id=617
The file uploads and is checked properly, the device performs the install and asks to reboot.
Once rebooted however, when I SSH and run "apt-get update", it returns with a "command not found" error, as if it were never installed.
I have tried installing multiple times, and other add-on's have installed correctly using the same method, such as enabling root SSH, the GIT addon, etc.
The only other thing I can think of trying is a factory reset, but obviously it's a last resort.
Any help would be appreciated.
1 Reply
  • Go to the root and type # which apt-get
    If nothing returns, then it can't find it based on your path.
    # cd / && find -name apt-get
ProSupport for Business
