fstrydom
Aug 03, 2018Aspirant
Readynas NV+ Stuck at Quota check
Hi All. My Readynas NV+ experienced a power interruption. When I turned it on afterwards, it got stuck at "Quota check 11.1%". I was not able to connect with Raidar at that point. During startup I no...
fstrydom
Aug 04, 2018Aspirant
Hi. Thank you for the reply. I have noticed it in the manual, but have not tried it yet. I was a bit cautious about the warning that goes with it. "Use this option to skip
the scan and let the system boot. Use this boot mode only if instructed to do so by a
NETGEAR technical support representative. Otherwise, you might lose data". I guess I will have to take the risk and do it. Have you had much experience with this option?
Aug 04, 2018Guru - Experienced User
Some (though I generally haven't needed it myself). I don't think it's particularly risky - and if the file system is damaged you often don't want the NAS to attempt to repair it.
- fstrydomAug 05, 2018AspirantThank you for the advice StephenB. I went with the Skip Volume Check boot option and after a few hours disk 2 were synched and the system is fully redundant. I can then shut it down and start it up without issues; however, if I browse some particular folders the system freezes, then I have to pull the plug to shut it down. Also, it looks like disk 4 might be the one that is actually starting to fail as i get notifications that ata errors are increasing on this disk.
- StephenBAug 05, 2018Guru - Experienced User
First download the log zip file, and look for disk errors there. Disk_smart.log has this info.
If it is disk 4, you can try powering down, and booting it with disk 4 removed, and see if that lets you complete the backup. I suggest backing up everything you practically can before you try this. Also avoid writing to the volume until you have copied everything off.
