mcpeterc
Nov 28, 2013Aspirant
ReadyNAS NVX - transmission 2.82 not starting
Hi friends.
I have been using transmission addon since forever. I have never had problems until I upgraded from version 2.7x to 2.82. After this update the addon wont start.
I have a copy of my settings.json file here (note umask is 0)
If i revert back to the old version everything works fine, tho i am NOT satisfied with my upload speed on this version. All the nessesary ports are open
best regards
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": true,
"blocklist-url": "http://list.iblocklist.com/?list=bt_level1",
"cache-size-mb": 200,
"dht-enabled": false,
"download-dir": "/c/media/BitTorrent",
"download-queue-enabled": true,
"download-queue-size": 5,
"encryption": 1,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/c/media/BitTorrent/Incomplete",
"incomplete-dir-enabled": true,
"lazy-bitfield-enabled": true,
"lpd-enabled": false,
"max-peers-global": 200,
"message-level": 1,
"open-file-limit": 32,
"peer-congestion-algorithm": "",
"peer-limit-global": 240,
"peer-limit-per-torrent": 60,
"peer-port": 51413,
"peer-port-random-enabled": 0,
"peer-port-random-high": 65535,
"peer-port-random-low": 1024,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": true,
"pidfile": "/var/run/transmission-daemon.pid",
"port-forwarding-enabled": true,
"preallocation": 2,
"prefetch-enabled": 0,
"proxy": "",
"proxy-auth-enabled": false,
"proxy-auth-password": "",
"proxy-auth-username": "",
"proxy-enabled": false,
"proxy-port": 80,
"proxy-type": 0,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": true,
"rename-partial-files": true,
"rpc-authentication-required": false,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{SECRET",
"rpc-port": 8181,
"rpc-url": "/transmission/",
"rpc-username": "SECRET",
"rpc-whitelist": "*",
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": true,
"script-torrent-done-filename": "/c/addons-config/Transmission/email_alert",
"seed-queue-enabled": false,
"seed-queue-size": 10,
"speed-limit-down": 100,
"speed-limit-down-enabled": false,
"speed-limit-up": 10,
"speed-limit-up-enabled": false,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 0,
"upload-limit": 100,
"upload-limit-enabled": 0,
"upload-slots-per-torrent": 14,
"utp-enabled": false,
"watch-dir": "/c/media/BitTorrent/sources/",
"watch-dir-enabled": 1
best regards
- mdgm-ntgrNETGEAR Employee Retired
- KymruAspirant2.84 will start/stop when fresh install, but as soon as i edit the settings.json, i get an error saying "transmission service failed to start"
but i can remote download via
Transmission Remote GUI on my computer
Transdroid on my phone and tablet
i can get access via the web interface for transmission
but no green light in frontview for transmission to say its loaded, if i reboot my NAS, i have to try and restart via frontview again
the only settings i have changed in settings.json are
"download-dir":
"incomplete-dir":
"watch-dir":
"rpc-port": - mdgm-ntgrNETGEAR Employee RetiredHow did you edit that file?
If you use an incompatible editor you can mess up the formatting of settings.json - KymruAspiranti have tried using nano direct from command line, i have tried using WinSCP and edit it with Ultraedit and Brackets, all edited from a fresh install after deleting the /c/addons-config/Transmission folder
get the same thing on every editor - mdgm-ntgrNETGEAR Employee RetiredYou didn't copy the file somewhere else, edit it and copy it back did you? Best to edit the file in place.
- KymruAspirantthe nano edit was done on the nas and that was the last one i tried, i thought the same that using WinSCP and editing it with ultraedit and brackets may be breaking the format in some way
but even using nano it fails to start
