ferg1
Dec 31, 2020Guide
Readynas Pro 6 stuck in power off - reboot power off cycle.
Hello. I've got a Readynas Pro 6, that I updated to the 6.0 firmware some time ago. It's been running flawlessly for a few years now.\ The unit is used for backup (Time Machine and rsync from Lin...
Sandshark
Jan 01, 2021Sensei
If you have (or can borrow from a PC) a standard ATX power supply, you can hook that up externally just to see if it is the supply. If it ius, the replacement is an SFX form factor one. If you are going to run it any length of time with the external supply, cover the gaps where the cable comes out and the internal power supply fan opening with masking tape to keep air flowing properly over the drives.
ferg1
Jan 01, 2021Guide
Thanks. That is certainly not the type of job to really be doing with a New year's Day hangover....! Those molex are pretty tight. I hooked up a spare ATX PSU. Now the unit briefly turns on then back off again. So I guess the issue is more serious. Oh well.
- ferg1Jan 01, 2021Guide
Weird...! I reconnected the old PSU and it booted up fine. It's now resyncing...! Either it was the UPS unit it was previously plugged into, or I did remove and reseat the DIMM when reconnecting the PSU cable. i wonder if that had worked itself loose? Seems unlikely. Anyway fingers crossed it resyncs fully, Thank you!
- ferg1Jan 04, 2021Guide
Weirder and weirder. I just powered off the unit to return it to its normal place under my desk. Once in place I powered it up again and the same issue reoccurs. It starts to boot then fails. This is after running for a few days without issue. I guess I'm now back at square one!
- SandsharkJan 04, 2021Sensei
Did you re-boot multiple time before this? If not, it could still be a failing power supply and you just got lucky to get through the initial current demand once.
Otherwise, perhaps a loose connection somewhere? Try re-seating the drives.
