ferg1
Dec 31, 2020Guide
Readynas Pro 6 stuck in power off - reboot power off cycle.
Hello. I've got a Readynas Pro 6, that I updated to the 6.0 firmware some time ago. It's been running flawlessly for a few years now.\ The unit is used for backup (Time Machine and rsync from Lin...
ferg1
Jan 01, 2021Guide
Thanks. That is certainly not the type of job to really be doing with a New year's Day hangover....! Those molex are pretty tight. I hooked up a spare ATX PSU. Now the unit briefly turns on then back off again. So I guess the issue is more serious. Oh well.
ferg1
Jan 01, 2021Guide
Weird...! I reconnected the old PSU and it booted up fine. It's now resyncing...! Either it was the UPS unit it was previously plugged into, or I did remove and reseat the DIMM when reconnecting the PSU cable. i wonder if that had worked itself loose? Seems unlikely. Anyway fingers crossed it resyncs fully, Thank you!
- ferg1Jan 04, 2021Guide
Weirder and weirder. I just powered off the unit to return it to its normal place under my desk. Once in place I powered it up again and the same issue reoccurs. It starts to boot then fails. This is after running for a few days without issue. I guess I'm now back at square one!
- SandsharkJan 04, 2021Sensei - Experienced User
Did you re-boot multiple time before this? If not, it could still be a failing power supply and you just got lucky to get through the initial current demand once.
Otherwise, perhaps a loose connection somewhere? Try re-seating the drives.
- ferg1Jan 06, 2021Guide
Thanks. But no go.
However, I managed to get it booted. When I did so I looked the logs and found out many Command Timeout messages for two disks....! Turns out I'd changed the password for my SMTP server a few months ago but forgotten to change it on the ReadyNAS. So the trusty ReadyNAS had been trying to warn me that disk 1 and 6 had many Command Timeouts for a month now. But I never noticed.
Two impending disk failures on a six disk RAID5 array...!
I bought two replacements then tried to figure which disk was failing. I chose disk6, but that refused to boot too. So it was actually Disk1 that was the culprit. By booting a degraded Raid5 array with two failed units out of six disks I've now messed up that array.
I am experienced enough to repare this situation if it was plain old RAID 5 using MDADM, but I have no idea if I can restore this array on a ReadyNAS. RAIDOS6 uses ZFS now right? Any tips for recovering my array?
(It's not critical as all is backed up, but it's a pain to reconfigure!).
Thanks!
