felbus
Oct 04, 2012Aspirant
ReadyNas Remote and Drop Nothing Works
Hi, I have a ReadyNAS Duo v2, RAIDiator 5.3.6 firmware. I went to the web admin page for my ReadyNas, and enabled readyremote and readydrop. I also installed the latest windows client. I then su...
mdgm-ntgr
Oct 27, 2012NETGEAR Employee Retired
They can access ordinary shares over ReadyNAS Remote with the conditions I gave above.
Yes http://www.readynas.com/remote is out of date and doesn't refer to the Dashboard.
However some of it is still accurate e.g Step 3 on that page refers to accessing NAS shares via ReadyNAS Remote.
ReadyDROP allows files you add on your PC to the ReadyDROP folder to automatically be synced to your NAS and vice versa. Whereas files saved to your ordinary shares via ReadyNAS Remote would just be on your NAS (unless you keep another copy on your PC).
