felbus
Oct 04, 2012Aspirant
ReadyNas Remote and Drop Nothing Works
Hi, I have a ReadyNAS Duo v2, RAIDiator 5.3.6 firmware. I went to the web admin page for my ReadyNas, and enabled readyremote and readydrop. I also installed the latest windows client. I then su...
felbus
Oct 27, 2012Aspirant
If it helps, another problem I am now experiencing is that when i login at https://readydrop.netgear.com or on the iphone app, although it says "connected as user" (and have tested those credentials over at readynas.remote login), both will not connect and show me anything.. Iphone says failed to connect, and readydrop webpage just constantly refreshes..
