felbus
Oct 04, 2012Aspirant
ReadyNas Remote and Drop Nothing Works
Hi, I have a ReadyNAS Duo v2, RAIDiator 5.3.6 firmware. I went to the web admin page for my ReadyNas, and enabled readyremote and readydrop. I also installed the latest windows client. I then su...
mdgm-ntgr
Oct 27, 2012NETGEAR Employee Retired
ReadyDROP is part of the ReadyNAS Remote client but after installing ReadyNAS Remote you do have to manually decide to use ReadyDROP on a PC so that shouldn't be an issue.
Another option for accessing the web-interface remotely would be to use your own VPN or to expose the necessary ports to the internet (the latter could pose a security risk if not done right).
