Crookz's avatar
Crookz
readynas remote arm duov2 download location
Hi all,
We can I find the readynas remote add on for the Duo v2 arm version?
Doesn't seem to be any links for this.
Thanks
  • calja03 wrote:
    Hi All, I'm having a similar problem in that ReadyNAS Remote doesn't appear in the list of add-ons (either Installed or Available). Is there somewhere that I can download it? The Sparc & x86 versions are no use for the Duo V2.
    Thanks in advance.
    Jim
    What version of firmware is on your Duo v2 ?
  • It's 5.3.6 I think. The NAS is actually at a customer site and I'm back at the office.
  • In 5.3.6 ReadyNAS Remote as been incorporated into the firmware, go to system > settings tab you will see remote access.
    Edit: they need to update the manual to show remote in no longer an addon and is part of the 5.3.6 firmware.
  • Many thanks Herbieo, it works a treat.
    What a shame the documentation isn't up to date. It's my first time using a ReadyNAS and it was almost my last.
    Once again, thanks for the information.
    Cheers,
    Jim
  • the problem is the readynas v2 is ARM and there are not many addons for it
ProSupport for Business
