Mills
Nov 27, 2011Aspirant
ReadyNAS Remote Duo V2 installation
I recently purchased a ReadyNAS Duo v2 and when I go to the add on tab to install readynas remote and click "get" a message comes up saying installation in progress, please wait for confirmation. I ...
wasted_d
Nov 29, 2011Aspirant
mdgm wrote: Did you delete the partitions (e.g. using a PC) on those previously used disks before adding them?
i actually tried it both ways, first by using the boot menu on the nas drive itself to do a factory restore, (holding reset, waiting for all lights then pressing the backup button) but i could not get this to do anything so i then put the drives into my pc an deleted the partitions. Then set the nas up again as i did the first time when i got it.
Nas Photo II and TransmissionBT both are both installed an working, this problem, for me, is just with the nas remote.
